Using Excel to Populate CLX Tags
Chuck Woodbury
Apr 2005
Valley Springs, California
78
I have a UDT with 166 Members,part of which has the 40P module definition. As part of the upgrade from a PowerFlex 40P to a PowerFlex 525, this tag gets deleted and recreated with the new datatype with the 525 module definition embedded. Uploading the data to excel is simple using the DDE Link available on the RSLinx OEM or Gateway. What is shown below is the vba code to use a command button to POKE that data back to the new tag.
I have set up my spreadsheet with all of the data for every VFD in the plant. All we have to do is enter the motor number in the cell and all of the Tags on Sheet 2 are changed and the data is populated using the VLookup from Sheet 1.
Push the CommandButton21 labeled "POKE" and it runs and populates the tag with that data. With over a thousand VFD's to upgrade, this cuts out any chance for fat fingering the data and reduces the amount of time it takes to upgrade a VFD.
Sorry about the way it copied to here but all of the REM statements begin '
Private Sub CommandButton21_Click()
'Set up Counter for the For/Next Loop
Dim LCounter As Integer
'Open the DDE Channel to the ControlLogix Processor via RSLinx
DDEChannel = Application.DDEInitiate(app:="RSLinx", topic:="Trainer_Room")
'Begin For Next where the Tags begin at row 3 and end at row 168
For LCounter = 3 To 168
'Define the Tag as a DDEItem and where it is located so the first tag is at Cells(Row3(variable LCounter), ColumnC(3))
DDEItem = Cells(LCounter, 3).Value
'Set the RangeToPoke where the data has to be converted to a range and the cell the data is in is the variable row LCounter column H (8)
Set RangeToPoke = Worksheets("Sheet2").Range(Cells(LCounter, 8), Cells(LCounter, 8))
'Poke the Data from Range to Poke
Application.DDEPoke DDEChannel, DDEItem, RangeToPoke
'Step the counter and do it again
Next LCounter
'When the Counter finishes (168) terminate the DDE Connection
Application.DDETerminate DDEChannel
End Sub
Earlier this year I used this approach to populate a 250-element array of UDT's, with 6 floating point values and 2 string values each. It took about 3-4 seconds.
We have recipes controlled by the brewhouse on an excel sheet, when they make changes they can download one or all of them by brand.
So far all of them by brand (can be up to 300) takes between 13-20 seconds, yup i put a timer in as i was curious
Ash
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
553
Hello, I am looking for help writing to PLC tags from Excel. I am using Factory Talk Gateway as an OPC server and Excel VBA to write out to an...
3,112
Good Morning , We had an equipment manufacture in last week. He always giving us a thumbdrive with the machine recipes . They are neatly in...
2,549
Hello there, world! The problem i'm facing up is about a registry I need to do in order to compare the set point versus the real variable I got...
1,585
hello guys... i m looking for example how to send excel recepi to wincc flexiable (HMI) and when click particular formula it will start using the...
1,848
