Using FC 92 with S7-1200/1500
blima
Aug 2010
Lisbon
96
Hello!
Is it possible to use the Function 92 with S7-1200 and S7-1500? Or do I have to stick with S7-300/400?
Is there a document where I can see the function of S7-300/400 that might be used with S7-1200/1500?
Or I can only look at the system manual of each specific hardware and see if has the type of function that I need.
Thanks,
Bruno
I am working on a project on an s7-1200 with an hmi, but I am looking to remove the HMI and substitute its functionality using the User-Defined...
1,935
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,932
Hello everybody. I need to print temperature data every 30 seconds. For this I need to print on a thermal printer that is connected to a CM1241...
1,472
How do you program a Micrologic 1200 RTD module using a Micrologic 1400 PLC? I'm using RSLogix Micro to program the ladder logic. I've wired the...
2,854
i am new in robotics programming and configuration. this is completely education project talking to ABB robot with devicenet option irc5...
1,953
