Using Indusoft VbSctript to find last insert id in MySql once every five seconds
I have tried using the following code:
Code:
'Find Row Number of current Job
Dim sql1,LII
sql1="Select LAST_INSERT_ID() FROM meererdb.run_summary AS LII"
$numCur=$DBCursorOpenSQL("MySqlDB",sql1)
$rownum=$DBCursorGetValue($numCur, LII)
$DBCursorClose($numCur)
It returns a value of zero when it should be 573
I feel like this should work.... but it doesn't
What am I missing?? (other than better VbScript skills)
Code:
Dim sql1,LII
$rownum=$DBCursorGetValue($numCur, "LII")
this: http://kbase.icbconsulting.com/home/indusoft
you want some form of $DBCursorGetValue e.g. summat like this:
Code:
sql1 = "SELECT LAST_INSERT_ID() AS LII"
$LII = $DBCursorGetValue($numCur, "LII")
$DBCursorClose(numCur)
Hi DrBitBoy,
I want to thank you for trying to help me, and apologize for my lack of understanding of VbScript......
So, do I need to specify the column name and table that I want the value from?
The auto-incrementing column name is run_key
I have tried changing LII in the code to run_key and it doesn't return anything. ($rownum doesn't change value)
Thank you again for the help....
Ah, got it. Maybe.
From https://dev.mysql.com/doc/refman/8.0/en/information-functions.html#function_last-insert-id:
The key phrase there is per-connection.
What that means is that you have to do the [SELECT LAST_INSERT_ID()] in the same connection, that is
  • after the INSERT in a database connection
  • AND
  • before closing that database connection i.e. the database connection that did the INSERT.
Is it possible you are issuing the [SELECT LAST_INSERT_ID()] query on a new database connection, separate from the database connection that did the INSERT, or perhaps after closing and re-connecting to the same database connection?
Well I couldn't get Select Last_Insert_ID() to work in Indusoft VbScript.
It always returned a zero no matter how I tried to configure it.
So I had to go with Select Max() and it works.
This is the code that seems to work best for me:
Code:
Dim sql0, RecordId,sqlD, tmpResult
sql0 = "Insert into mdb.run_summary (machine_id) values ('" & $Getcomputername() & "')"
$DBExecute ("MySqlDB",sql0)
sqlD="SELECT MAX(run_key) as RecordId FROM mdb.run_summary;"
tmpResult = $DBCursorOpenSQL ("MySqlDB",sqlD)
$rownum = $DBCursorGetValue(tmpResult,"RecordId")
DrBitBoy, thanks for all the help!!
I wouldn't use MAX unless there is an index, but since this is your primary key should be by default. You could also order by 'run_key' desc and limit/use top of 1.
Did you ever contact Indusoft? Just hard to believe they don't have this built-in where you can request the key from the initial query.
Cool beans. Gotta love reverse engineering. Since is are only ever adding one record, and letting the INTEGER AUTO_INCREMENT field be auto-incremented, that should always work.
For the record, and I just remembered this, it may (may) be possible to send multiple queries over one connection in one SQL string using the MySQL semi-colon separator e.g.
Code:
sql0 = "INSERT INTO [...] [COLOR=Red][I][B];[/B][/I][/COLOR] SELECT LAST_INSERT_ID()"
See the attachment, which is admittedly from a Linux command line using the mysql client; processing multiple queries my not be built into the AVEVA $DB.. API.
I have been searching for a way to insert a line into a MySql database once every five seconds. I was using Advanced HMI and the timer tick...
23
6,405
I am working on a project where I need to accumulate the amout of Runtime of a machine. I am presently able to display the length of the "Current...
3,179
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
