Using PT100 sensor with a SIEMENS CPU313C
Henrik_Raabe
Nov 2007
Ry
Hallo everybody
Im pretty new in here about 2 min he he, i would like to get som help setting up my PLC, i have worked with step 7 before but its 5-6 years ago.
I have a CPU313C with build in PT100 Input, i have a ETF-197 PT-100 sensor from OJ ELECTRONIC in denmark, it have a range from -40 to 125 C
I have connected the PT-100 to the input on the card, and set up the hardware so its schould be a RTD-2L PT100 input, then i go to the variable table to monitor the input, my AI range is from 3 to 12 so i monitor my IW11, i get hex W#16#7FFF and its not changing.
What i need the temp for is to start a pump at 65 C and stop it again by 50 C, could somebody also help me explaine how to make that program.
Hi all, I have PT100 (0-100deg C) connected to an EM231 analog input module on a Siemens S7 224. When I check the status with MicroWin I can see...
2,943
Hi, I wrote a sequence loop using EQU and MOV instructions and would like to validate that i'm doing this properly. i attached a picture of the...
399
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
55
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
97
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
156
