Using SFB47 in OB33 Interrupt
Ktn
Sep 2008
Cape Town
Hey all. I have a few FC blocks that run well on the Siemens PLC[314C-2DP], but as soon as I add the OB33 [500ms interrupt] interrupt with a SFB47, the block doesn't download to the PLC. See attached code for the OB33. Can anyone please assist.
I think there is only OB35 in 300-series , you can cahnge interrupt time what you like in HW-Config. Default value is 100ms.
As the previous post, check the properties of the CPU to show which cyclic interrupts are available and to set the time interval. The 314 only has OB35 as shown below:
Hello, I have a system where I want to monitor some motors to make sure they are running and if not generate an alarm. The PLC is already using...
2,775
Hi guys, I'm currently working with a siemens PLC 314C-2DP and am using the fast counter input(channel 2) with an incremental encoder...
5,176
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
38
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
84
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
139
