Using the HIM CopyCat Function
Tugce
May 2018
Turkey
Helle,
How is the 20-HIM-A3 CopyCat function used for the Powerflex 700 series drive? I am waiting for the help of your knowledgeable friends
Welcome to the PLCTalk user forum community !
Do you have a specific question about HIM Copycat ?
In general, you use it to save all the parameters from a drive into the keypad Human Interface Module (HIM) device.
Then you plug that HIM module into a new drive, and use the menus to reverse the process and copy the parameter set from the HIM to the drive.
That allows you to copy all the parameters from one drive to the another, without using software tools or manually setting up each parameter.
Thank you very much.
in fact, which menus I should ask to use.
Can you help me exactly how to do this.
Here are some finer details...
32099 - PowerFlex 7-class: Procedure to do the HIM CopyCat Function
Access Level: Everyone
Note the links to the drive series user manuals at the bottom and which Appendix provides specific details.
Regards,
George
Hello,thank you so much but I can not access the site.
Do you have the opportunity to share datasheet here.
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
38
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
79
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
134
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
249
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
79
