USS comm between MM440 and 224XP
manmeetvirdi
Oct 2004
India.
750
Hi there,
I want to read the MM440 current and display it on HMI
Iam using the PLC 224XP and USS protocol.
Iam able to start/stop and change the speed of the drive through USS_CTRL block.
The setting of P2012(PZD length)=2,and P2013(PKW length)=127, as mentioned in the help file of Microwin.
*Now will the drive current can be configured in Drive to read it in PZD2?
Moment i change either the value of PZD or PKW other then the default values, i get drive error from USS_CTRL or speed which i'am feeding simply refues to reach drive!
Looking forward for suggestions
Manmeet
Here is a link to some S7-200 programming tips and examples. Tip 65 and 28 might be particularly helpful with USS. I have not used them, so I cannot comment on their value. I came across them while looking for help using USS with an S7-300 and MM420. Perhaps you may find a use for them. S7-200 Programming Tips (Entry ID 1232912)
Does a solid state soft starter have a DC Buss / DC Buss voltage like a VFD does?
257
Hey all. Looking for a 24v module that can act as a modbus tcp slave and also a MQTT client. I want to be able to send modbus data to an external...
1,862
How do you get the uss drive control to output specific status words on outputs "Status1" Status3" and Status4" of the uss drive control FB? I...
4,152
Dear Friends; We have a BOBST 1228 flexo printing machine having Siemens S7-300 PLC (6ES7 318-3EL01-0AB0) and Lenze 9300 and 9400 drives. The...
2,324
Hello, I'm used to using Allen Bradley RIO options for putting filed IO out in the field and running my safety back to it. Of course I have to...
2,878
