Uticor 6001 Director Loader Program
HowardH
Dec 2011
Goodwell, OK
Hi All -
I'm trying to connect to a 6001 Director (mid 90's era device) and we cannot find the "Progam Loader" software documented in the manual.
Does anyone know where I can get a copy of it??
I've tried using the uWin software download from Uticor, but it seems unresponsive. Uticor tech support told me later that would not work, anyway, even though I noticed the uWin software offers the 6001 Director as a PLC option for creating new projects.
The Uticor tech support said they didn't have a copy of it, but I know someone has to have one floating around, if the older software is truly the only thing that will communicate with it.
I think we have the appropriate DB9 serial cable for connection, so I think it is a software issue.
I would sure appreciate any advice or comments.
Thanks a lot,
Howard Henderson
I don't have the software for the old Uticor screens any more - sorry
But it used a standard null modem db9 rs232
(DB9)rs232 - (DB9)modem port
this was 4 notebooks ago
Hmmm, the only references to a "6001 Director" I find is in a Uticore manual that says it's a plc, not HMI. So it's no wonder that uWin won't talk to it.
The Director 6001 option in uWIn is when you select the PLC driver to use / connect.
Sniffing around leads me to think that unit was first a Struthers Dunn Director 4001/6001 so try searching for that. Also look for EZPLC http://flash.ezautomation.net/ezplc/firmware_ezplc.htm
hello, we are using allen bradley plc 5/15 with uticor hmi pv700. but now we replace plc 5/15 with 5/20 but the uticor hmi is not communicating...
924
I have Allen Bradley PLC 5/15 installed with AB Panel View 1400 using DH+ communication on machine. As PV 1400 is now obsolete so i m replacing it...
3,267
I have a UTICOR message display that was connected to a PLC 5/20E channel0 serial port, RS-422 (5 wires GND, SD+, SD-, RD+, RD-) I've upgraded...
1,915
Hey guys, I am faced with making a tough decision of choosing between a Red Lion G3 series HMI and a Uticor Tough Panel. I have heard great things...
7,300
I have several UTICOR PMD200 message displays that I want to replace. What do you recommend for a good cost effective replacement?
1,637
