Variable table value is not matching with Function block value in S7
Maybe you used different representation of you variable table value and FB value?
did someone mention block consistancy?
select "blocks" in project tree, then "edit" from the menu, go down to block consistancy.
Save all check BC download all to PLC.
That is if nothing is actually wrong in your code.
Hello, does anybody know if it is possible to replace a table name within a FSC expression with a variable that updates the table name based off...
1,285
Could somebody please point me in the right direction? I'm trying to incorporate a table into each motor's faceplate. It's a simple, two...
3,214
Hello guys, i have this weird issue with citectscada: whenever I create a new project and define the servers and the tags, both variable and...
1,523
What signal i can change/Modify from variable table in Simatic S7 300 CPU : Input,output, Memory Bit, DataBlock signal and what is the convenient...
1,738
Hi, here's probably another easy question for you, but a frustration to me: I'm new to programming in STEP7, but have been learning a lot the...
3,182
