VARIAC Question
leitmotif
Nov 2004
Seattle Wa. USA
3,680
Have a "standard" or very commonly used bench top variac fused for 10 amp -- output is 0 to 140 VAC. The question I have is this
is it an autotransformer or an isolated secondary transformer??
BACKGROUND
Have a need to bench test AC and DC components (motors solenoids relays etc) at various voltages.
PLAN bring in 120 and then select for either 120 Line or Variac ie "LINE or VARIAC".
IF autotransformer I intend to isolate the primary and the secondary with contacts on the "LINE or VARIAC" select switch.
I will only break the hot conductor and not the neutral.
Either Line (120 AC) or Variac will supply full wave bridge. This will also be a controlled function of the "LINE or VARIAC" select switch.
There will be analog readouts for each of AC and DC volt and current. I may go digital on this to conserve space and to prevent pegging analog meter needles.
Any other thoughts? Have I got my mind right??
Dan Bentler
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
89
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
197
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
195
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
108
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
114
