VB code to write tag value into RSViewStudio
Paglia
Mar 2007
Milan
I've devoleped a VB application for retrieve data from an Access database and now I wont write this values to some tag into my RSView studio stand alone application.
I've tried with a reference to "DisplayClient" and then to create a TagGroup object and then add a tag to this object, but doesn't work...
Can you help me????
Thank you, Virginio
I've found the solution, If someone is interested:
Sub SetUpTagGroup()
Dim oCl As Application
On Error Resume Next
Err.Clear
If oCl Is Nothing Then
Set oCl = displayclient.Application
End If
If oGroup Is Nothing Then
Set oGroup = oCl.CreateTagGroup("/", 500)
If Err.Number Then
LogDiagnosticsMessage "Error creating TagGroup. Error: " & Err.Description, ftDiagSeverityError
Exit Sub
End If
oGroup.Add "TEST_TAG"
oGroup.Active = True
End If
End Sub
Sub SetTagValue()
Dim oTag As Tag
If Not oGroup Is Nothing Then
Set oTag = oGroup.Item("TEST_TAG")
Err.Clear
oTag.Value = 10
' Test the Error number for the result.
Select Case Err.Number
Case 0:
' Write completed successfully... log a message
LogDiagnosticsMessage "Write to tag " & oTag.Name & " was successful."
Case tagErrorReadOnlyAccess:
MsgBox "Unable to write tag value. Client is read-only."
Case tagErrorWriteValue:
If oTag.LastErrorNumber = tagErrorInvalidSecurity Then
MsgBox "Unable to write tag value. The current user does not have security rights."
Else
MsgBox "Error writing tag value. Error: " & oTag.LastErrorString
End If
Case tagErrorOperationFailed:
MsgBox "Failed to write to tag. Error: " & Err.Description
End Select
End If
End Sub
Hello Friends.... I am trying to read & write the PLC tags through VBA code but not getting correct syntax, i m using FTView SE 6.0 Your help will...
8,274
Does anyone know what Key Code does? This is linked to the button called "Alarm Ack." I searched for device FFB4 in the code but couldn't find...
2,125
Hi, complete novice here. GXDeveloper: I work in a test facility controlled by Q-series PLC. I want to do some self-training on ladder logic...
22
4,159
Good Morning everyone, I need your help to rewrite the code or better way to write the code because honestly I didn't like how the code is right...
27
8,030
Need good example/sample of aoi RSLogix5000 code to read&write through RS232 port on Need good example/sample of aoi RSLogix5000 code to...
1,844
