Hi all.
I am trying to write vbs code to copy data SQL from one server to another .
i can write data to blockdata, but i cannot copy data from blockdata to WinCC.
pls show me where i wrong, thanks all
here my code :
Sub OnClick(Byval Item)
On Error Resume Next
Err.Clear
Dim conn, rst,rst1, SQL_Tabelle,Dat_Nr,Block,n,conn1,SQL_Tabelle_1
Dim DnoteNo,LogNumber,BlockNumber,ActualLength,InvoiceLength,SED,LED,Taper,Sweep,Date_T,Dnote
Set conn = CreateObject("ADODB.Connection")
Set rst = CreateObject("ADODB.Recordset")
conn.Open "Provider=MSDASQL;Initial Catalog=AA;DSN=WinCC7"
conn1.Open "Provider=MSDASQL;Initial Catalog=WINCC;User ID=WINCC;Password=123456;DSN=WINCC"
Block = SmartTags("Block")
Date_T = Now()
n = 0
Dnote = SmartTags("CurrentDnote")
LogNumber = SmartTags("DnoteLogNumber")
RejectCode = SmartTags("RejectCode")
If Block >= 0 Then
BlockNumber = 1
ActualLength = SmartTags("Block1Length")
SED = SmartTags("Block1SED")
LED = SmartTags("Block1LED")
Taper = SmartTags("Block1Taper")
Sweep = SmartTags("Block1Sweep")
SQL_Tabelle = "INSERT IGNORE INTO "&"blockdata"& " VALUES ('"&Dnote &"' , '"&LogNumber &"' , '"&BlockNumber &"', '"&ActualLength &"', '"&SED&"', '"&LED &"', '"&Taper &"', '"&Sweep &"', '"&Date_T &"')"
Set rst = conn.Execute(SQL_Tabelle)
End If
MsgBox "OK"
SQL_Tabelle_1= "INSERT IGNORE INTO "&" [PTOUCH2-PC\WINCC].WINCC.dbo.WINCC " & " Select * FROM "& "blockdata"
Set rst1 = conn1.Execute(SQL_Tabelle_1)
MsgBox "COPIED"
End Sub
here my code :
Err.Clear
Date_T = Now()
n = 0
If Block >= 0 Then
BlockNumber = 1
End If
MsgBox "OK"
MsgBox "COPIED"
End Sub
