WinCC scheduling a VBS to run
Blue Fox
Feb 2013
Basildon
49
Hello all,
I have written a VBS script to read a group of tags, and put the values and tag name etc into a text file when I press a button on one of my SCADA pages. This all works well with no issues. However what I would like to do is to remove the button and have it do this automatically twice per day at 06:00 and 18:00 (shift change). I'm really not sure how to do this as have very little VBS experience (the reading tags is the first I have done). Any help would be much appreciated.
Regards
Its ok I figured out out - is quite simple using the built in triggering functions. All now working having tested using a couple of other times, is reading tags perfectly.
I am using WinCC Flex 2008 Advan and i want to create a buliding automation project, i want to bring on outputs from the HMI over a 24 hour...
2,247
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
31
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
48
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
72
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
70
