TConnolly
If I understand you the piston operates a lever which moves the cart 1 meter. Assuming we are talking metric tonnes here and not USCU tons, the cart has a mass of ~150 kg, but because of the mechanical disadvantage of the lever the piston sees a load of 250 kg and the piston stroke is less than 1 meter. Is that correct? If so then what is the distance the piston travels? Once we know that we can calculate the acceleration and required force.
Based on the info so far this beyond the capabilities of most PLCs for motion control. But that doesn't mean we can't help - some of the forum contributors are motion control experts.
A sketch will be really helpful.
Other pieces of helpful information include the hydraulic operating pressure, pump size if it has already been selected (hopefully it hasn't as it might be inadequate), and cylinder size if it has already been selected (again hopefully it hasn't as it may surprise how big it needs to be).
