Hello all,
I'm having a bit of trouble with our GE Fanuc Versamax PLCs. We currently have a IC200UDR164 PLC with a Ethernet-to-RS232 module. Communication is through the serial port on Port1 and Ethernet on Port2.
Everything worked fine for most of our PLCs, but a couple of them suddenly stopped communicating on Port2 in Machine Edition when an attempt to program the PLC was made. Our standard procedure is to then use Port1 to re-establish connection in these cases. However, Port1 was also non-responsive (ie. going online times out). None of the PLC lights were blinking either (PWR and OK were solid green).
Subsequent attempts to use known good cables/computers, as well as power cycling and letting the supercap discharge over multiple days did not help either. The Ethernet module was even removed to eliminate it as a potential source of problems.
Does anyone have any suggestions on what I should try next?
