VersaMax CPU Communication
rrice0725
Aug 2021
Scottsboro, Al
I am trying to connect to a new VersaMax CPU (IC200CPU002) via the RS485 port. I have two CPU's. One was taken off a machine and the other is new. I can go online with the old CPU without any issues so I know my setup is correct.
When I first powered the new CPU up I was able to go online and download to it. After a power cycle it is faulted with the light staying steady. When I try to go online the Port 2 light comes on steady for about 15 to 20 seconds, then goes off, and comes back on after another 20 seconds, without ever connecting.
Any ideas? Is there any way to reset the fault without going online?
A quick GOOGLE search indicates that if the Fault light is blinking AND the OK light is off a fatal fault has occurred. They recommend calling product support.
If the fault light is on steady and you are in Stop mode, that is also a fatal indication.
Dear Folks, We had a defective CPUE05 where we managed to replace & download the program, the program we downloaded has been saved from an other...
2,965
I have some Versmax controllers that start in this mode after a power outage. Any ideas on how to make them start in Run mode after power has been...
1,152
Hi guy we just finish a job with a GE CPUE05 Versamax. The last week-end the cpu reboot all alone and was reset to factory state, the program and...
5,301
Fixes error indication "system configuration mismatch" the module of PLC VERSAMAX CPU I'm having the case of PLC VERSAMAX GEFANUC error. It is...
8,153
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
231
