Good Afternoon All,
I have been tasked with controlling 3 SVX9000 VFD's with the OPTC7 option board through a devicenet network using a GE Versamax controller and the IC200BEM103 NCM card, I have configured the VFD's to be nodes 11,12,13 with the baud rate set at 500kbps. I also see 23.9V at each drive across the power wires and 60.2 ohms across the CAN-H and Can-L wires, so I think the wiring is done correctly. I've attached the relevant rungs of logic I used in the PLC to configure the devicenet module, once the program has done a transition from stop to run and the configuration has been sent to the module I get a 1 in the status register which means"Successful Status - Network operation can proceed" at which point I think it should start polling and communicating correct? however it doesn't seem to start comm's and I have no idea what I've done wrong. any help is appreciated
andrew
andrew
