VersaView? PanelView Plus CE?
Greg Dake
Jun 2005
Milwaukee, Wi
550
Greetings,​
Normally I purchase the standard Panelview Plus line of HMI's from AB. I've also purchased a VersaView in the past. Is the VersaView now what is called the PanelView Plus CE? It looks that way.​
I need to know if I can install VNC server on a PanelView Plus CE. Is there even a VNC server available for the CE OS? I see there are many VNC viewers on the web for the CE OS, but little or no VNC servers for CE. I want to acess and control the PanelView Plus CE. Has anyone done this?​
TIA,​
Greg​
Ha, yes, that's the other one I looked at. It's uncompiled and you need Visual C++ to compile it, which I do not have.
I have found a few others on the web which I will test tomorrow. If I have success I will post the link back here for future users.
Thanks for your input,
Greg
I kind of figured that you had came across that. I just figured that I'd give it a shot since nobody else was posting.
Good luck.
I got it!
We tried compiling the VNC server CE that was on Sourceforge.net and it didn't work after the compile.
I talked with a Rockwell guy and he said it is on the CD that ships with a VersaView. We dug out the CD and sure enough, it had VNC Server for CE on it! We copied the required files to CF and we installed on the VersaView. It works like a charm. We now have remote access to the Versaview.
Thanks,
Greg
Has anyone tried to update the windows XP on a AB Versaview/Panelview +CE. Or am I going to have to replace the whole unit. Our IT group is...
1,746
Hi all, have anybody heard something about the new Panelview Plus (or VersaView CE) line of HMI panels from AB ? There are some marketing blasts...
8,372
First of all i just took over support of a large operation and they use alot of different AB HMI's ... the regional mgr wants me to upgrade...
2,076
Hello, I am working on a project under Schneider M580, We have an existing supervision PC station develloped with Wonderware Intouch. The...
959
Hi all, I've got a facility that has multiple VersaViews across the floor. Every time I change the HMI, I've got to load it on each of them. Does...
698
