Robb B
Hello, I was wondering if anyone has some insights into a VFD controls scenario. We have a VFD controlling a pump which is currently setup so that the operators can manually input a specific RPM (600 - 1800 I believe) which the drive will obviously maintain very effectively. The operators have requested the ability to input a flow rate in Gallons Per Minute instead of RPM, in order to try to achieve a flow through the pump. This seems reasonable, but I wonder if there is some caveats that I should know of before implementing such controls. I do have a minimum speed approx. 20% as a hard lower limit on the drive, but I wonder if the drive will end up "hunting" for a speed which satisfies an inputted GPM.
