Viewing Drawings on RedLion G310
Old No. 7
Jun 2010
Ohio
173
Has anyone found a good way to put electrical drawings on a G310?
I tried the .pdf viewer, but it is painfully slow. It takes about 10 seconds to open the drawing and another 10 seconds if you zoom in/out. I looked at just showing the drawing as an image, but I don't think you can zoom on an image and the drawings would be difficult to read.
Anyone come up with something better?
the delay is usually due to file size
can you resize to a smaller size or BMP file
there are programs that can reduce picture format sizes
the freeware name eludes me for now
Hello,
You have tried the two options available. The PDF viewer is probably best but as noted might be too slow for the operator. The image could work if the resolution allows it to be viewed properly.
Jeremy
the program was GYMP
but may not work for PDFs
I think you mean GIMP: http://www.gimp.org/downloads/
Another one that is simpler and quicker to learn is IrfanView: http://www.irfanview.com/
For resizing graphics in a pdf, you need to work out a compromise between the two file formats as the pdf will embed the graphic and depending on your pdf generation software you may or may not have options to optimize the embedded graphic.
I got my PanelView Plus 7 working with a Micrologix 1500. How would I connect my laptop to the PanelView to view the ladder logic while operating...
162
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
141
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
396
When I added device Powerflex 525 to my project,The ( current tag) was not populated .How can I retrieve this data ? Thanks Jeff
561
Hey all, looking for some opinions/recommendations for Modbus server viewing software. Have a PLC that we're reading directly from the modbus...
1,912
