Vijeo Citect 7.4 I get #COM error when use new tags
JulioMtz
Feb 2006
Mexico City
Hi everyone,
I'm getting a #COM error with Vijeo Citect SCADA version 7.4
This system has been working fine for several years. But now that I need to add some instruments and therefore I need to create new tags, I get these errors.
As i make new variables in Vijeo Citect SCADA manually adding a variables under project editor, there comes #COM error on runtime.
The new instruments (variables) in the PLC are correct, the readings are ok.
I have not made changes in the configuration of the communications with the plc because I am only adding variables in the plc and tags in Vijeo Citect.
Does anybody have a previous experience with this issue and knows how to fix it? Maybe I need to update someting in the Db, etc
I need to absorb data from remotely installed 4 MICOM P122 relays to my VIJEO CITECT via MODBUS RS485 network. Parameters like FAULT RECORDS...
2,501
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
487
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,679
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
897
