Vijeo Citect Tag Addressing
TahirQ
May 2013
Riyadh
54
How do you refer the variables in unity pro by tags in Vijeo Citect. I know that %I and %Iw can be represented as %M. For example %M10001 would refer to %I0.0.0. But how would i refer %I0.2.X or %Q 0.1.X ?
Dear all, I am currently using vijeo citect 7.4 and i would like to import my unity pro xl variable database. I import it using the express...
6,028
So I have need to display volume and run times on my screens for some equpiment. I recently got some help from support but things are still not...
11,536
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
479
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,672
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
889
