Vinyl wrapping a backplane
bkulrich
Jun 2017
North Carolina
Anyone ever vinyl wrap a backplane, and is it acceptable to do so? We are building a panel for 15 VFD's, and thought about using a vinyl wrap to locate all holes. Equipment labels could be incorporated.
Welcome to the forum.
If you wrap the backpanel in order to mark the drill holes and then remove the wrapping when you are done, OK.
BUT you cannot leave this wrapping on when done. the wrapping creates an insulation barrier between the components and the backplane which is grounded to the enclosure. this also prevents heat dissipation to the backpanel. i would not allow this to remain on the backpanel if i were still in the panel building business.
james
james
Paint does the same thing, doesn't it?
Archie shared some pictures at one time where he had the backplane either vinyl wrapped or silk screened. Looked pretty sharp.
Do you mean the back PLATE of an enclosure? Or the BACKPLANE of a PLC rack?
As Bob1371 stated Archie has a sign company make a vinyl stick-on in full color that covers the back PLATE for drilling mounting holes.
Plus as James said, I would cut out anywhere that a component needs heat disappation
Sorry, I do mean back PLATE of an enclosure...
my 2 cents (although something in me head saying don't):
Some manufactures use the back plane as an equipment ground.
I didn't even think about the heat angle.
I will ask my UL guy next time I see him.
Actually on painted back plates the grounding is through a bonding washer that cuts through the paint or powdercoating. They don't rely on the frame of a component touching bare metal.
W
Has anyone ever replaced the vinyl overlay on a PV600 touchscreen? Is this part available from AB? Or have you found a way to remove the scratches...
2,661
WillardWhite
W
Can you wrap rungs in ladder in Unity Pro? I couldn't figure out a way to do it, so I just added a temporary Bool output to the right side, then...
1,827
Hello We are considering retrofitting our wrapping machine, a Signode Sprialgrip 500, with modern, non proprietary controls. The only hangup is...
3,046
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
99
I noticed something that’s mostly just a curiosity. Maybe someone here knows. An IT system is reading a L82 with the on-board IP and 1,0 added...
701
