Virtual PC XP to run Step 7
sculliesfox
Mar 2008
Ohio
Has anyone tried to run Siemens step 7 in a virtual PC? We do not do a lot of Siemens programming and typically I have a dual boot system because Siemens and Rockwell don’t always play nice with each other on the same machine. The problem with dual boot is that I don’t have all my basic programs such as office and email. I have a Dell D830 with a T9300 2.5ghz core 2 and 4 gig of ram running XP pro.
If anyone has tried this, or has another idea, I would like to hear from you and see what I can do.
Thanks,
Eric J Hohman
2-B ?
| 2-B |
i havent tried it myself but ive seen Step7 on virtual pc and that is prob a good idea if you have different programs
I use VMware and use it with various programming software, including STEP7.
Ethernet and the PC Adapter USB plays well with VMware.
CP5511, CP5512, CP5611, CP5621 does not.
It has been discussed before. Use the search function.
I have a Panasonic tough book running windoze 7. I use the Windows XP mode. It works OK slower than if not in a virtual world. You have to attach the drivers manually right click attach lets say USB mpi converter.
After installed you don't even have to run the windoze XP mode. just run it straight from windoze. I like it because I have some older programs written with Protools not winCC so the XP compatibility is a must.
HI.
i work with VPC but i dont conect to plc SIMATIC manager work well in VPC. i think u dont have any problem with that.in vpc u can configure serial port + ethernet + usb then i think u can use pc adaptor to connect the siemens device.
We are in the same situation. I use Virtual PC with XP for Step7. I connect with either serial or enet and don't have any problems. Virtual PC won't support USB for XP which may be a concern for you. Virtual PC for Windows 7 however does support USB. If USB is a concern for you then as mentioned in the previous post, VMWare will support USB in an XP environment.
Good Afternoon , I have a machine that has 7 - Kinetix 6000 servos on it . All the servos want to run high speed and cannot slow down...
2,155
Need to run (or transfer license ) FT View Studio 6 on my XP Virtual Machine Morning. Have old FT View projects that were created in 32 bit OS...
5,085
Hi all, I would like to replicate my PC onto a virtual machine so I could use it on a different laptop when I'm on site. I have never created a...
254
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
718
Is there any way to use a Virtual HMI (running on a PC) with CCW? This is for an application where there will be an actual HMI (PV800) connected...
413
