Vision Sensor
Bratt
Nov 2003
West Sweden
726
Maybe i little off topic but i give it a shot anyway :) . We are about to invest in several visionsystems for inspecting that silicon have been laid out with good results. We are currently using laser senors for this task but they are very time consuming since the robots or nc axis have to go around the same path twice.
Anyway now to my question we have come down to two suppliers. Cognex and Rvsi. Both companies seems to have good products and i wonder i any of you guys have positive or negative experience with the products of theese suppliers and which supplier we should choose.
Have them do a test on your actual parts before you buy anything. Never delt with Rvsi but Cognex always did that for us when I was at my previous employer.
Make sure you give them parts that represent actual production conditions. Many times, people only supply "perfect"= parts for testing or parts that have been cleaned or altered in some way. Vision is sensative in ways normal sensors and switches are not. It's a whole different way of thinking.
Make sure you give them parts that demonstrate all the failure modes or features you expect to detect.
There seems to be a lot of black art left in the "science" of vision inspection.
Good Luck
Hi All I have a small job where we would like to destack a stack of pallets I would like to use a 3D sensor to give me the position of the top...
1,494
Hi, I'd like to set up a connection between an IX Vision Sensor and a Micrologix 1100 from Rockwell Automation through EtherNet/IP protocol. Does...
1,089
Does anyone have experience with both these of sensors in regards to ease of use, setup, capabilities, support etc. Any thoughts would be greatly...
5,088
First off great form with a lot of useful info and people. My question is if any one has used a ifm model 02D224 Vision sensor.I am looking to use...
3,859
Howdy All!, Looking for some feedback from anyone who has worked with / installed Vision sensors. Looking to see if a Vision sensor can...
5,620
