VJD - understanding Scripts
safalya
Apr 2013
India
Hey,
Am new to Vijeo designer have understood how to use int, real and string type syntax-es.
However, with boolean I'm stuck.
I can display boolean on a string or numeric display. But how do I make the following scripts work?
1. boolean PopupWindowName.moveOffset(int X, int Y);
2. boolean PopupWindowName.changePanel(int panel_ID);
3. boolean PopupWindowName.show(boolean Status);
Could you show me a sample?
Also why does PopupWindowName.open(int X, int Y);
not work without 2 & 3?
Thank You.
I am using Allen Bradley PLC for Ethernet/IP communication. I send any explicit msg request (Get attribute or Set attribute), I observed packet...
90
Took a new job and the controls schemes are fairly old and I'm used to Allen Bradley and Siemens. I'm looking to replace a pair of Superior...
120
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
378
Good day is there somewhere i can see the situation and compatibility regarding different firmware revisions. I have a 2711-K5A5, series H and...
228
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,109
