Help with understanding GE 90-30 APM module
IHICONN
Mar 2024
Ohio
Took a new job and the controls schemes are fairly old and I'm used to Allen Bradley and Siemens. I'm looking to replace a pair of Superior Slo-Syn Drives with some kollmorgen akd servo drives. Boss won't approve replacing the PLC with a more modern RX3I PLC so I need to pair these new servo drives to the GE 90-30 IC69APU301 that already exists.
I have the manual for it but I'm struggling to understand its purpose in the system. It seems like it stores the drive program but could someone more familiar with it give me an overview of how I would approach the programming to make the new drives work? The wiring seems straightforwards enough to swap over by itself but how do I copy over the drive program?
The module is capable of executing stored programs or executing commands to move. It outputs a -10 volt to +10 volt DC analog speed reference and reads an encoder feedback signal. To execute a stored program, PLC logic turns on one of the %Q output bits assigned to the APU301 module. To execute a direct move command, the PLC moves a command code and associated data into the %AQ analog output addresses assigned to the module.
If your company will permit it, post the PLC program here and I'll point out the logic that controls the existing servo. If the boss isn't comfortable with posting the program on a public forum, contact me via PM and I'll give you my email address to send it directly to me.
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
348
Hi, To give some context of the situation and why I'm posting. I started a PLC module as part of a general engineering course last year and the...
2,028
https://imgur.com/a/kKPtzyP We are making improvements to these motor controls by replacing these old resistor banks and DC generator with DC...
1,788
I get so confused by Rockwell's licensing structure. I have two PC's that will be running the same SE application. Can/should I run this as...
1,827
Hello Everyone, Just need some help with understanding something. Info: I had a compact logix L32E processor faulting and would not reset and...
1,203
