Help understanding compact logix network setup
bendanator
Dec 2018
convington
27
Hello Everyone,
Just need some help with understanding something.
Info: I had a compact logix L32E processor faulting and would not reset and could not connect to the processor or see it on the network. I eventually worked to the idea that it was the processor that was the problem. When I switched out the processor and downloaded the program I could finally connect to the plc but could not see any other devices over the network which in this setup is a panel view plus and a Powerflex 525 VFD. I have photos I hopefully attach correctly at the bottom. But in the I/O configuration there is 1769-L32E port LocalENB which sets up the connect to the PowerFlex 525 and other devices. But as I opened the module properties and went to port configuration the
IP address was set to 10.10.131.1
Subnet mask 255.255.248.0
Gateway address 10.10.120.1
Powerflex IP address from the pervious set up is 138.150.100.3
Subnet mask 255.255.255.0
Was wondering why the processor port configuration changed with the new processor card. I would have thought downloading the program would have kept the addressing. Would I have to do this with every processor change? Or why did it change?
Any other info I’ll do my best to proved. Thanks
Address is set independently, a program download does not set it. It appears that processor may have been pulled from another system, previously configured. Regardless, it won't communicate with that PF in that configuration.
Took a new job and the controls schemes are fairly old and I'm used to Allen Bradley and Siemens. I'm looking to replace a pair of Superior...
111
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
351
Hi, To give some context of the situation and why I'm posting. I started a PLC module as part of a general engineering course last year and the...
2,030
https://imgur.com/a/kKPtzyP We are making improvements to these motor controls by replacing these old resistor banks and DC generator with DC...
1,789
I get so confused by Rockwell's licensing structure. I have two PC's that will be running the same SE application. Can/should I run this as...
1,829
