VLans
Alan Case
Apr 2002
Wagga Wagga
1,268
Hi. I have a factory as a client that has all the AB processers connected via ethernet using managed switches. Most machines basically are stand alone but a few talk to the upstream/downstream machine to control the feed rate. Not overly critical if this comms fails to work for a time as a nearby operator can manually turn off the feed if required.
What they are wanting is to allow remote access for the OEMs to each of their machines for fault finding if required.
They only want to allow the OEMs to view the machines when the factory wants them to and only allow each OEM access to his machine. The switches are managed Hirschman.
What I am thinking is dedicating one port (the last port) on each switch to VLan 2. All other ports in the factory will be on VLan 1.
VLan 2 will be connected via a router to internet.
Normally the factory will run with everything plugged into VLan 1.
If an OEM wishes to view his machine remotely the on site technician unplugs the machine from VLan 1 into the last port (VLan 2). The only problem will be that the unplugged machine will drop off the scada (not a big problem) and also if it is talking to an upstream/downstream PLC then this comms will be lost. This is not a huge problem but it would be nice if we could tell VLan 2 to allow certain IP addresses to bridge VLans.
ie if PLC 192.168.210.100 talks to 192.168.210.110
and if PLC 192.168.210.120 talks to 192.168.210.130 then can we program the VLans to allow comms between these above 4 IP addresses. This is so that if an OEM wishes to view 192.168.210.100 we plug it into VLan 2 which will only allow him acess to the one PLC but will also allow 192.168.210.100 to continue talking to 192.168.210.110
I hope the above makes sense or is there an easier way to do it.
Regards Alan Case
Do you have someone around that manages the switches?
I don't think VLANs are the best solution here. The right way involves programming the router/VPN concentrator to only pass traffic to/from certain IP addresses with Access Control Lists. Disable the vendors VPN user account when they don't require access.
This tacky alternative might work:
1. Create a separate VPN connection for each vendor
2. Each VPN connection only allows communication to their device based on choosing a subnet mask such that the only node on the "network" is their device. (security through different network settings, humm...?)
3. Logically enable/disable entire VPN connections as needed.
Hope everyone is doing well, I have 7 off Stratix Switch 5700(SW01,02,03,04,05,06 and SW07), each switch is connected to different CIP nodes such...
1,301
Hi, I created this post recently and got some great information: http://www.plctalk.net/qanda/showthread.php?t=127080 One thing I'm trying to...
2,819
Hi, I'm trying to get my head around how plant networks should be set up, and I've created a few topics on this before. One new question I have...
30
11,900
Hey everyone, First project working with a managed switch, chose to use it due to having a DLR network with 8 drives. Local PLC (let's call it...
3,952
Hi, I have a couple of PC's on our network, one that's been in a good few years, and one that I have just installed next to it. The issue I have...
3,539
