Hope everyone is doing well,
I have 7 off Stratix Switch 5700(SW01,02,03,04,05,06 and SW07), each switch is connected to different CIP nodes such as Powerflex drives , SIEMESN SIMOCODES, Compact Logix , Scada InTouch , Prosoft Gateways, all switches are connected as star topology to the main Stratix switch (SW01) which has the main PLC Guardlogix controller.
all CIP nodes from all switches plus the main PLC (GuardLogix controller) are in the same subnet starting 10.100.13.X
I wanted to segregate the traffic by using the VLAN; creating VLAN for each Switch say; VLAN10,20,30,40,50,50 and VLAN70 , leaving the IP addresses as the same as they are 10.100.13.X .
Would the GuardLogix controller still communicate with the different CIP nodes across all the switches SW01,02,03,04,05,06 and SW07,
GuardLogix controller is residing in SW01 , which gateway address do I have to use for all CIP nodes , would it be the IP address of the GuardLogix controller residing on SW01 , or the IP address of the SW01
Appreciate the help
Appreciate the help
