Hello All-
I have a project which my client wants to change the set points when the PLC is still online. In my program the set points are stored in flash and then called to the registers upon controller booting, I can alter the registers to change the set points when the controller is online, but after a power cycle everything is back as flashed. My controller does not support flash/non-volatile memory manipulation and my client doesn't want to use an addon battery pack.
I am wondering if there are controllers (from any vendors) that support flash memory manipulation ? Any recommendation would be grateful.
Thank you.
Thank you.
