GE RX3i write/read non-volatile memory
herrergu
May 2017
Houston
I am using the lader logic SVC_56 & SVC_57 to write and read data to the PLC's flash memory. I've followed the instructions to configure the service calls but no luck. I don't even get the success or error return codes.
Has anybody done this successfully?
Get the IPI or manual for your CPU or look it up in PME online to to verify that your CPU supports that Service Request and its proper use.
Sorry I'm on my phone or I'd have more detail.
On those CPUs protected with an "energy pack" ALL RAM is saved on power loss so there is no need for those "Service Requests. See PME online help for those functions.
I contacted GE IP support and they say the CPE330 does not support those calls and they suggested, like you, that I use the energy pack to save all RAM to flash upon power down. Thanks for the help. (y)
Using GE RX3i PLC with Machine Edition SW... I have a decimal %R number (value is "1150") that I want to write to a set of 16 %I bits to set 1 and...
18
4,761
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
389
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
284
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
106
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
976
