WAGO question
arocon
Oct 2006
Dubai
171
I am new to WAGO system. I need to send one analog signal from a CPU.
So i bought WAGO fieldbus coupler 750-841 and WAGO analog output. I want to connect CPU with WAGO fieldbus coupler with ethernet and Modbus TCP.
If anybody please tell me step by step procedure what i need to do then it will be great help. I need send only one data to Wago analog output module from CPU through Wago fieldbus coupler 750-841.
I have read manual but i am not clear .
Thank you for your help.
841 is a real controller so you can put a program and a vis in it.
with CPU you mean a standard Personal Computer?
If really only one signal i would look for an arduino as this is cheaper.
Assuming that it's the only (or 1st) analog module in your controller (and the 750-841 is a controller, and an old one at that) the data for the 1st analog input will be at Modbus address 40001. That will be the case if you use any of the 750 controllers or couplers.
Yosi
I am having the shop guys load the wago plcs that we are shipping w/ the .img file via the plc built in web page. It appears as if most everything...
729
When updating the firmware in a Wago plc, it tells you to bkp the data. Is there a program that can do this?
2,159
Hello guys, I got a question. I have a Wago 750-841 with some modules. I try to control the PLC using Modbus TCP which is working great so far...
1,278
I'm having trouble locating string data to %MW registers. This does not appear to work: site_name AT %MW200: STRING[20];
1,571
Hey Guys, Im trying to work out the Modbus memory map and the tags on the Beijer x2 HMI and 750-881 WAGO PLC. Have looked up the forum and found...
4,331
