Want to control speed of AC drive using another AC Drive
psaundary
May 2015
Agra
Hi i want to control the speed of AC drive using Another Drive reference output . please help me :cry:
And also i am confused in practical hard wiring :(
Hello,
There are several ways this can be done, it will just depend on exactly what you have and exactly what it is you are trying to accomplish.
Assuming you want drive #2 to run at the same speed as drive #1 (drive 2 will follow drive #1)
You can wire from drive #1 Analog Output to Drive #2 Analog Input.
Then set drive 2 frequency setpoint reference as Analog Input.
Now drive 2 should follow drive #1.
You can also scale these different from each other or set up offsets if you need drive 2 to follow drive 1 but run a different speed.
Give a little more info on what you are using, Drive Type, Model #, and if these drives are networked together or not. This will make it easier for someone to give you more detailed information to your specific drive.
BCS
How to select speed control bandwidth of a motor drive ? If anyone explain with specific example it will be great help
1,923
I replaced an old Safetronics drive with a PowerFlex 400. I have 5.6 vdc at terminals 13 and 14 . P038 is set to 2 ( Analog In 1 ) , T069 is set...
3,562
Is 'precontrol' never or rarely used in the speed controller of a drive? Is a speed controller always a PI(D) controller? Why no precontrol (if...
2,598
I just saw that in a Danfoss drive you have the ability to use precontrol in the speedcontroller of the drive (FC302 drive). I thought that...
2,723
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
969
