Mark Buskell
I refers to those type of bits as memory bits. Example: Part Detected Memory, Part Released Memory. How you set them is up to you using a timer, seal, latch, etc.
rsdoran said:This is a situation where you need to know if something has been ON then goes OFF (or vice versa) to enable the next rung/step of the operation.
rsdoran said:Are all or should all plc programs be state machines? Should they all use a sequencer because in reality you have to always do a sequence?
I was offering, and hoping others would too, the HOW TO in understand how to handle events, does not matter how you program.
Why do y'all have to make it so hard for some to understand?
This was simple, X occured, not that X WAS you can do Z.
Does not matter whether you program in Ladder, IL, STL, or BS. It just offers an idea to help comprehend.
Such a simple concept but now I understand why so many have problems with it.
rsdoran said:That is exactly what my program does. A product, on a conveyor, has to go PAST a sensor before you can do anything further.
Has nothing to do with the whole program, just a concept that may be part of a program.
djbillyd007 said:I did a very simular setup on a old shanklin L sealer. I used a dl-06 and set up a positive edge belt go and then a negative edge fire one shot to run belt until time to seal. not sure what a good name for this would be but it worked. By the way are u working in GA by any chance??
EVENT TO FORGET
REMEMBER EVENT WAS BIT
WAS BIT |
Switchman said:I have several Shanklin A27A L bar sealers that operate exactly like this. My older ones run about 28 ppm and the new ones about 35. The older ones use simple photoeye initiate and off delays with SLC 100. The newer ones have SLC 5/03 still with a PE. Same basic programming though. Settings through a pot on several. Several have DTAMs or PV550 with adjustment there.
I'll look later when I get some time and if still relevant shoot you the ladder stuff.
