detrimental1
Need to find a way to zero out some registers on 1st scan if programming was just downloaded. Want to differentiate between a 1st scan following a power off event as opposed to a 1st scan following a download / Does the processor record the fact that a download has been performed? Perhaps with a status bit? If I download the processor with my latest file, but someone has changed some setpoints after my last backup, via touch screen input, I want to zero out some registers that contain setpoints, so that I don't inadvertantly let the machine run with the wrong setpoints. In this case, the machine would not run until a machine tech came, and filled in the correct setpoints again. If just the power goes off, and then gets turned back on, I don't want to zero out the registers, as the setpoints will still be the ones that were in the machine when it was powered off.
