Saving test bit status on power failure
BOWILLY
Feb 2013
Wasaga Beach, Ontario
35
I am new to Mitsubishi GX2 and GX3 software here at work. It is common practice to use an "M" memory bit as a temporary bypass. This is done by programming a N.O. bit and then toggling it on. It is also common practice to leave this in the program for extended periods - end of production run, product changeover, weekend etc. Is there a way to save the status of this collection of "M" bits on power loss and then reload the on or off condition on power-up? Recently got burned when power was cycled to a processor with such a bit active. On power-up , the software sets the bits's value to 0. Scrambling to find this undocumented change was an "adventure" .
You can use the latch relay or a bit of a D memory (Q series)
You need to set the retentive range for those as in picture
Open up the parameters & there you can set the latch range of a number of bit/word types.
Yes on the Q series you can also use D registers at bit value i.e. D10.0
It is a good idea to put many of those in the latch area i.e. D L etc. that way they are battery backed up R (Fie registers are different, you can create a file either in ram or SD card if fitted this also retains the status I often put a range of the D registers in the latch area for things like engineering or recipe variables so these retain the data on power down.
Hi everyone, i have an issue with saving a changed value in an AOI, I am using L84E, Everytime i try to save my work to SD card, the program lost...
96
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
98
Hello, i have a problem, i was trying to fix a trend that wasn't registering the tags, i got that fix by setting the path, but now i can get it to...
833
I'm struggling with this...Times and Dates are always a mental-block for me. See picture. When I press SAVE, I want to take the current...
1,696
Hello, I have a couple of problems with the directsoft 6 software. I couldn't find a previous answer, and uninstalling and reinstall hasn't...
1,486
