Water flow with time
Charbel
Jan 2012
Beirut
307
Dear,
I am looking for a simple solution showing the time of flow throughout the day, during the 24 hours, when is the flow passing through a pipe, any idea? any smart device able to provide this information?
thank you,
charbel
Dear,
thank you,
charbel
Are you not interested in the flow rate itself, just the times when there is water in, or moving through, the pipe?
What is the orientation of the pipe (horizontal, vertical, sloped)?
Is the pipe supported along its entire length, or are there discrete supports? How big is the pipe and how frequent are the stanchions?
What makes the water move (head/gravity, pump, etc.)?
Can you put anything inside the pipe, or does the device need to detect water from outside the pipe?
I'm looking for some general guidance on creating a flow meter controller in GTDesigner3. The pump supplier said that the inverter can be...
27
7,041
All, My client is looking to have me calculate the boiler feed water differential pressure in kPa to and actual flowrate in m3/hr. Once the...
1,547
Hello everyone I need some suggestion from you. We are controlling the flow of water in one of application. Our problem is the set point is...
4,019
I need to control DI water flow rate at about 45 kg/min. The water come out from a day tank and water will pass a centrifugal pump, a E+H Mass...
32
17,944
Hi all, We have a large watertank and from that large watertank we try to supply the water to our watertreatment as constant as possible. But we...
1,504
