Way OT, but since magnetic fields seem to be "in" at the moment
Yup, that's it!
I'll be back down there in a couple of weeks, when they hope to have the first serious go at the 100 Tesla target. The 80 Tesla limit mentioned is for a single magnet, to hit 100 Tesla they first produce a basic field of 30+ Tesla in a large outer magnet for a period of a few hundred ms and then, when it's at its peak, pulse a small concentric coil inside the larger one to superimpose a further ~70 Tesla field on top of the basic 70 T field. This pulse will last for a maximum of about 50 ms, but until now fields of 100 T have only been achievable in self-destructing systems (Mission Impossible?) and the fields only lasted a few µs.
I love the final sentence in the article I linked to -
Scientists from laboratories and universities worldwide will be welcome to use the giant magnet without charge.
Well, if there's no charge, what have you been doing with all these big capacitors for the last few years?!?!
Regards
Ken
(... second thoughts...)
Or does it mean it's free so long as you don't want to actually switch it on?
QUOTE]It's the output end of one module of the world's largest capacitor bank (only discovered that tit-bit, myself, last week).[[/QUOTE]
Since the highlighted word should have been tidbit, maybe the process has other charges it provides, appears to be some subliminal thoughts being provoked.
I jes had to do this Roy, awesome project though.
After researching the word it does appear that it is titbit in the UK and tidbit in the US...just another word we had to do over and get it right.
Good Morning , Since I’m loading a new laptop , what are you doing for the 32 bit FactoryTalk View projects that you run into ? Are you...
3,849
Been quite a while since I had to deal with Logix 5000, back then there was no Studio, it was just RSLogix5000, and IIRC you had to have each and...
17
7,489
Hi! I'm trying to find the most accurate way of calculating todays date, based on the number of days elapsed since January first 1984...
2,537
I have created a task that executes every 10ms, it uses a GSV to determine the time and set a flag once 8am has occurred. I use a periodic task to...
3,280
So I have a factorytalk me application running on a PC (xp) that has been working great until I installed RSLinx classic single node on there to...
3,519
