Webvisu via SoMachine (Schneider)
Vinnie_vdb
Aug 2011
Ghent
I am using the latest SoMachine (4.2) and exploring the possibilities of the build-in webserver. I got things running and such, no problem but (there is always a but :) ) I like to enter an INT value in my browser rather that adjusting a potentiometer but strangely enough is there no such thing in the toolbox. In fact, the toolbox is not that extensive on possible symbols.
So, actually 2 questions:
1/ How can I enter an INT value through my web browser?
2/ Is there something like an OSCAT library that has more open source symbols for webvisu?
Thank you already for the help.
You can use a text field. Its in the toolbox under common controls. You have to enter a placeholder %d (for decimal value)
Then under the text variable enter the variable you want to display.
Then under input config select write to a variable
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
319
Hi! Anyone know if it possible to use UserManagement with SoMachine web visualization? The library does exist and the tab to configure it also...
1,231
How can I trigger the web browser to refresh based on a variable? ie when I receive a new image have FF / Chrome refresh. What I'm trying to do...
4,336
Hi Everyone! I am using a WAGO 750-881 for a small project, and I wanted to have a web visu, done with Codesys 2.3. The visu (PLC_VISU) works...
6,223
Hi guys Using somachine 4.1 sp1. When i run the web vizu in chrome i get an error that your browser doesn't support html5 canvas. Even though this...
3,765
