Weidmuller PLC5 Migration System
jsmith1817
Aug 2012
NC
i have not used it but do have about 8 plc5 migrations to do over next 5 years or more. it looks like the chassis becomes a marshalling rack only and your i/o is mounted elsewhere and the remote I/O adapter is redundant and can be removed completely.
Having used the Rockwell migration, I quite like it.
The one issue I had was that the digital output conversion cards have fuses in them which are non-standard.
I can see where Weidmuller are coming from with this, but usually on a conversion, you would want to have the new PLC in the same footprint as the existing PLC, whereas this looks like your new PLC is elsewhere, depending on the cable lengths for the cards.
Not sure I would use it for my needs.
Hello cruel world, from GregATyler.
An old boss has a small problem he has asked me to help him with. GE FANUK controller, motors, and sensors already installed on a custom CNC Machine that is ready to go out the door, but since GE quit the Controller business, and SUPPORT of same, his customer does not want it.
SOoooo ... does anyone know which product to is the best to replace a GE FANUK PLC Controller with, that will run the same custom programming, that again, is already done and ready to go out the door?
Thanks for your time and consideration.
~Greg
Good evening guys, Please, I need help. This is my first time working with RS485 comm and I dont know what to do. Please, see attached files. I...
424
Hello, Anyone has ever worked with Weidmuller MCZ SC 0-20mA (Threshold Limit-Value monitoring) signal conditioner? I read the datasheet and so...
925
Just thought I would share this https://youtu.be/piDb9_zWwJo Love the fact that all software sits on the controller. Will try to get a unit soon...
996
Hi team, has anyone been using WAGO or Weidmuller IO on Ethernet/IP? Both parties say no problem, both have YouTube clips showing it being added...
2,609
I have a little problem. I have a number of now classic SLC5/05's with which I am hoping to connect to Weidmuller ER20-FCB-EIP I/O nodes. I have...
1,848
