Weidmuller Ethernet/IP to SLC5/05 Connection
fredmatic1
Oct 2014
Dothan, AL.
I have a little problem. I have a number of now classic SLC5/05's with which I am hoping to connect to Weidmuller ER20-FCB-EIP I/O nodes. I have searched the Allen-Bradley knowledge base libraries and also on the net for a piece of example code, to no avail. While Weidmuller makes some pretty good hardware, they have limited 'non-German' manuals and even more limited explanations of their code. My SLC5/05's are OS500, Rev. C's and cannot be upgraded to OS501.....so no EEM instructions available. Can this be done with the MSG command? Is there any way to send the Attribute/Class/etc. required by the blocks?
Welcome to the PLCTalk forum community !
Unfortunately, what you want will not work for several reasons.
The first is the essential "they aren't meant for that": SLC-5/05 controllers are not designed, advertised, promoted, or supported to create and operate cyclic I/O connections on Ethernet.
Your SLC-5/05's sound like they are very early units, as much as 25 years old. My recollection matches yours: OS500 Series A could not be upgraded even with a physical EEPROM plug.
So not only do they not have EEM instruction support, they don't even have EtherNet/IP transport to send messages to ControlLogix. They can only use CSPv4 to perform data table reads and writes with other PLC-5E, PLC-5/250, and SLC-5/05 controllers.
I don't know the Weidmuller products in detail, but I have never seen a third-party I/O product that implemented A-B CSPv4 and emulated SLC-500 data tables for I/O control. Even A-B variable speed drives that emulate SLC-500 data tables only do it over EtherNet/IP transport.
Hi team, has anyone been using WAGO or Weidmuller IO on Ethernet/IP? Both parties say no problem, both have YouTube clips showing it being added...
2,595
Good evening guys, Please, I need help. This is my first time working with RS485 comm and I dont know what to do. Please, see attached files. I...
413
Hello, Anyone has ever worked with Weidmuller MCZ SC 0-20mA (Threshold Limit-Value monitoring) signal conditioner? I read the datasheet and so...
924
Just thought I would share this https://youtu.be/piDb9_zWwJo Love the fact that all software sits on the controller. Will try to get a unit soon...
994
I am working on a PLC5 upgrade quote and I came across this system from Weidmuller. Just curious if anyone has used it and what their thoughts...
1,484
