Weighing Powder
Nelliyan
Sep 2011
90
Hi all,
I was assigned to develop an architecture for the system in which i have to calculate the amount of powder that will be inleted in to a tank.
Now the tank will be placed in the testing bed & then user will fill it to a certain level,once done they will stop the powder inlet & quantity was measured by the no of times the user puts the powder inside the tank..Each time 100 gms..
What mechanism must be used to measure the powder till 100 gms & letting it inside the tank & again & agian till it reaches the specific point.
Regards,
Nelliyan.G
normally you fit load cells to the support feet and use a weight controller.
also you use two valves one for fast feed and one for slow feed.
this can be controlled directly from the weight controller.
you only need to Tare and Zero/reset etc. digitally
makes the process easy
Hello Everyone, I am trying to connect a A&D EK-6100i Weigher to my Micro 800 PLC and read the current weight. For now I have managed to connect...
4,192
Hey guys, I have a problem reading weighing data from AND AD4406 with OP-05 RS-232C Relay and Control input using Rockwell PLC Micro820. I already...
946
Hi. I need to troubleshoot a Modicon TSX Momentum 170ISP00100 Weighing Module. This hardware was discontinued by Modicon a few years ago. Does...
1,004
Hi. I need to troubleshoot a Modicon Momentum Weighing Module Model 170ISP00100. These modules have been discontinued by Modicon. Does anybody...
877
Hi, I have to make an weighing system with load cells. Here is what I had understood until now: Load cells: Sensibility often 2mv/V Recommended...
29
8,570
