weintek MT8070iE to Wago 750-881 via MODBUS TCP/IP results in PLC no repsonse
Gaz25
Jan 2008
Bedford
I have a Weintek MT8070iE HMI connected to a Wago 750-881 PLC via an Ethernet cable. The communication is set to MODBUS TCP/IP protocol.
The problem I have is that on the HMI, I get a message PLC no Response.
Here are the things that I have tried.
I have set the dip switches on the Wago PLC so that the IP address is 192.168.1.100
Connected a laptop to the PLC and sent some modbus commands and received expected replies so I know the PLC is OK.
Tried both cross-over and straight though Ethernet cables between the PLC and HMI
I can connect to the HMI though the PLC and download programs to it so I know the connection is there.
I have included screenshots of the settings on HMI for the PLC.
Try 8000 for the port. You have it at 502 now.
Did you set the IP address in the HMI. Not sure about the e series. You have to do that on the older ones.
Hey all! I'm working with an Automation Direct H2-DM1E PLC and have an Weintek mT8070iE HMI. I am trying to figure out how to configure the comms...
2,513
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
232
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
597
I have been using two of these HMIs on two sites with similar projects but developed separately. Now i want to use screens from one on the other...
391
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
958
