Weird issue with Digi One IAP & Dyadic servo amplifier
rguimond
Jul 2009
Escuminac
666
We've been using a Digi One IAP as a Realport device (Serail to Ethernet) to allow a device (Dyadic actuator & amplifier - http://www.miraiintertech.com/home/scn6.php) but it has been flaky, to say the least. Sometimes, the software could connect immediately, but sometimes it would take 20 or more tries. Sometimes, the IAP had to be rebooted several times.
Yesterday, on a whim, I tried usin an Automation Direct FA-ISOCON to convert the RS-485 signal from the amplifier to RS-232. Using an Automation Direct D2-DSCBL programming cable, I connected the FA-ISOCON to Port 2 of the IAP and, suddenly, it's working perfectly.
It's really strange. The IAP should be able to accept RS-485, RS-422 or RS-232 on Port 1 without issue (assuming DIP switches are set properly).
Has anyone encountered a similar issue? I've used a lot of IAPs and Realport devices for similar applications and they've performed very well.
i found that when the digi one IAP couldn't connect to one of the slaves it would reboot itself rather frequently. If the serial connection to the digi one IAP didn't work but through an isolator it did I would suspect it is a serial issue such as not having a common ground or as you say DIP switches for baud etc.
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
151
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
761
Hello all, I Have a PointIO module with 2 input cards. The Revision is 6.013 and it is connected to a ControlLogix running version 24.11 The...
2,376
Hello all, I have a weird problem in rslogix 5000. Few of rungs the instruction shows UNK. I have the attached the screenshot of the program. I...
8,165
Hi guys, Can I firstly say that, apart from today that I havent had much to do with Allen Bradley software/hardware, and when I do it always...
3,874
