Hello all,
Work has a copy of citec scada so as a side project i have been trying to set it up and running. I have hit a bit of a wall with getting it to talk to a PLC.
Its installed on a VM & the VM can ping the PLC im trying to connect to. I have attached a series of screenshots to show how i have set it up. I cant attach enough images so added a imgur album below.
https://imgur.com/a/vBZB408
Im using Citec Scada trying to talk to a compactlogix plc. I went through the setup wizards in I/O devices and am using the ABCLX Driver.
I created a page with some buttons to see if i can watch a tag change stage from the PLC. I have set the buttom to watch the tag CommsSts.DN wich is just a on/off pulsating tag, i would assume the little red light would go on and off if it can see the tag.
I can run the active project without errors.
Any ideas?
Any ideas?
