Westinghouse PLC
rkduet
Oct 2003
23
Instruction set definitions or manual. I have 3 that I'm not sure of "SL" I think may be a sequencer by it's structure, and an "AT" ?, and a "BT"
I can't seem to locate any online material, didn't expect to. All I can hope for is someone to have an old Instruction Set/ User manual,that could be scanned and e-mailed to me.
hi
AT ASCII TRANSMIT it is serial command
BT BLOCK TRANSFER move function
i did not find SL in special functions tabel there are (SK,SM,SP,SQ) i am on line now i check the manual if i find some thing i shell answer .....if not....
hi
AT ASCII TRANSMIT it is serial port command
I have problem whit communication on this device . When I check pc status in softwere i get error type "communication error". My cable for RS232...
2,472
I would like to get help with our Westinghouse PC503 made by Siemens. PLC is fine but our HMI/OIT unit made by Maple Systems, model WES460A stoped...
4,609
I am trying to communicate with an older PLC a Westinghouse 1100. All I want to do is retrieve the existing ladder so I know what is in this beast...
1,833
Hi I am brand new to this site but have programmed PLC's since the early 80's. I just acquired an older dial machine that has a Westinghouse PLC...
2,127
Hello every body we have a Westinghouse PLC 1100 , for one of our mixer machines,this PLC is old and has alot of problems,so i am changing it with...
2,683
