Wet AB TouchScreen 1000
coacht
Nov 2009
Tennessee
32
Guys
I have a AB 1000 Touchscreen that has got wet and went black and will not reboot. We do not have the program on file anywhere! Any Suggestions. Is there a way that I can upload the program and just buy another touch screen?
Well normally I wouldn't publicly suggest this but you really don't have much to loose...
Preheat your oven to 150F, bake for 4 hours and try again
If it did not work then tell us the complete catalog number of your PV and someone will tell you how to upload the program.
Well, first of all does the unit power up? If it doesn't, chances are that the power supply shorted out. A power supply can be replaced with one salvaged from another PV 1000. If it does power (light on the back lights up) then it could be the screen. With some effort the program can be saved, I think.
Good Afternoon , We have been using Seal Shield Washable keyboards in the plant. These just don't last, and even after we buy a few, only...
1,796
Hello. We had our fire suppression system trip last week (while we were snowed out of the plant), and it sprayed so much water that our PLC...
26
5,931
Not sure if anyone works in this field or deals with these machines. Very high voltage (low amperes - 100mA or so). We are building a prototype...
1,364
Dear all, Good day, Please i need your help as i have a condensate surge vessel and mounted on it two level transmitter(DP type).one for (HH and H...
16
3,486
I am using a Siemens s7-300 PLC and need to add a second wet well level. Basically the system will utilize the primary wet well level...
2,132
