RADIXSORT isn't there ! ( it's another kind of sorting ... without comparison)You can see the various algorithms animated here..
If you play around with it, you will see that the "best" algirithm depends on the "initial conditions".. e.g. random, nearly-sorted, etc.
the algorithm makes a difference but not in the way you might think.
DATA_BLOCK "SORT DB"
TITLE =
VERSION : 0.1
STRUCT
A : ARRAY [0 .. 17 ] OF REAL := 0.000000e+000;
END_STRUCT ;
BEGIN
A[0] := 0.000000e+000;
A[1] := 0.000000e+000;
A[2] := 0.000000e+000;
A[3] := 0.000000e+000;
A[4] := 0.000000e+000;
A[5] := 0.000000e+000;
A[6] := 0.000000e+000;
A[7] := 0.000000e+000;
A[8] := 0.000000e+000;
A[9] := 0.000000e+000;
A[10] := 0.000000e+000;
A[11] := 0.000000e+000;
A[12] := 0.000000e+000;
A[13] := 0.000000e+000;
A[14] := 0.000000e+000;
A[15] := 0.000000e+000;
A[16] := 0.000000e+000;
A[17] := 0.000000e+000;
END_DATA_BLOCK
DATA_BLOCK "HELP DB"
TITLE =
VERSION : 0.1
STRUCT
END_STRUCT ;
BEGIN
END_DATA_BLOCK
FUNCTION_BLOCK "SORT FB"
TITLE =
VERSION : 0.1
VAR_INPUT
START : BOOL ;
DB_Sort : BLOCK_DB ;
DB_Help : BLOCK_DB ;
LOOPTIME : INT ;
END_VAR
VAR_OUTPUT
BUSY : BOOL ; //Not ready
END_VAR
VAR
START_FM : BOOL ;
SELECTIONBIT : BOOL ;
DBNO_Sort : WORD ;
DBNO_Help : WORD ;
BITSET : DWORD ;
STEP : DWORD ;
BIT_Sort : DWORD ;
BIT_Help : DWORD ;
LOOPCOUNTER : INT ;
END_VAR
VAR_TEMP
DBNO_tempS : WORD ;
DBNO_tempH : WORD ;
ADDRESS_Sort : DWORD ;
DWNr_Sort : DWORD ;
DWNr_Help : DWORD ;
M : DWORD ;
END_VAR
BEGIN
NETWORK
TITLE =
A #START;
FP #START_FM;
JCN END;
OPN #DB_Help;
L DBNO;
T #DBNO_Help;
OPN #DB_Sort;
L DBNO;
T #DBNO_Sort;
L DBLG; //BYTE Anzahl des DB
L L#4; //DWORD Anzahl des DB
/D ;
+ L#-1; //(zählt von 0 an)
L L#32; //DWORD = 32 BIT
*D ;
T #BITSET;
CLR ;
= #SELECTIONBIT;
L L#0;
T #STEP;
T #LOOPCOUNTER; //.
SET ;
= #BUSY;
END: NOP 0;
NETWORK
TITLE =
A #BUSY;
JC GO;
BE ;
GO: NOP 0;
NETWORK
TITLE =
L #LOOPCOUNTER; //.
L 0; //.
>I ; //.
JC s4; //.
NETWORK
TITLE =
L #STEP; //SCHRITTNUMMER
L L#4; //MOD 4 (ROUTINE_WIDERHOLFAKTOR)
MOD ; //ZYKLIZITÄT NÜTZEN
L L#0; //TYP 0
<>D ;
JC s1;
L #STEP;
L L#16;
/D ;
T #M;
L L#0;
==D ;
L L#24;
JC B1;
L #M;
L L#1;
==D ;
L L#16;
JC B1;
L #M;
L L#2;
==D ;
L L#8;
JC B1;
L #M;
L L#3;
==D ;
L L#0;
B1: T #ADDRESS_Sort;
L #STEP;
L L#16;
MOD ; //Teilen auf Periode von 0-31 (= bits in 1 dword)
L L#2;
/D ; //Nochmals Teilen auf Periode von 0-7 (= bits in 1 byte)
T #BIT_Sort;
L #ADDRESS_Sort;
+D ;
T #ADDRESS_Sort;
L L#0;
T #DWNr_Sort;
T #DWNr_Help;
L #DBNO_Sort;
T #DBNO_tempS;
L #DBNO_Help;
T #DBNO_tempH;
NETWORK
TITLE =
s1: NOP 0;
L #STEP;
L L#4;
MOD ;
L L#1;
<>D ;
JC s2;
L #STEP;
L L#16;
/D ;
T #M;
L L#0;
==D ;
L #BITSET;
+ L#24;
JC B2;
L #M;
L L#1;
==D ;
L #BITSET;
+ L#16;
JC B2;
L #M;
L L#2;
==D ;
L #BITSET;
+ L#8;
JC B2;
L #M;
L L#3;
==D ;
L #BITSET;
B2: L #BIT_Sort;
+D ;
T #ADDRESS_Sort;
L #BITSET;
T #DWNr_Sort;
T #DWNr_Help;
L #DBNO_Sort;
T #DBNO_tempS;
L #DBNO_Help;
T #DBNO_tempH;
NETWORK
TITLE =
s2: NOP 0;
L #STEP;
L L#4;
MOD ;
L L#2;
<>D ;
JC s3;
L #STEP;
L L#16;
/D ;
T #M;
L L#0;
==D ;
L L#24;
JC B3;
L #M;
L L#1;
==D ;
L L#16;
JC B3;
L #M;
L L#2;
==D ;
L L#8;
JC B3;
L #M;
L L#3;
==D ;
L L#0;
B3: T #ADDRESS_Sort;
L #STEP;
L L#16;
MOD ;
L L#2;
/D ;
T #BIT_Help;
L #ADDRESS_Sort;
+D ;
T #ADDRESS_Sort;
L L#0;
T #DWNr_Sort;
T #DWNr_Help;
L #DBNO_Sort;
T #DBNO_tempH;
L #DBNO_Help;
T #DBNO_tempS;
NETWORK
TITLE =
s3: NOP 0;
L #STEP;
L L#4;
MOD ;
L L#3;
<>D ;
JC s4;
L #STEP;
L L#16;
/D ;
T #M;
L L#0;
==D ;
L #BITSET;
+ L#24;
JC B4;
L #M;
L L#1;
==D ;
L #BITSET;
+ L#16;
JC B4;
L #M;
L L#2;
==D ;
L #BITSET;
+ L#8;
JC B4;
L #M;
L L#3;
==D ;
L #BITSET;
B4: L #BIT_Help;
+D ;
T #ADDRESS_Sort;
L #BITSET;
T #DWNr_Sort;
T #DWNr_Help;
L #DBNO_Sort;
T #DBNO_tempH;
L #DBNO_Help;
T #DBNO_tempS;
NETWORK
TITLE =
s4: NOP 0;
AN #SELECTIONBIT;
JC oo0;
NETWORK
TITLE =
A #SELECTIONBIT;
JC oo1;
NETWORK
TITLE =
oo0: NOP 0;
o3: L #DWNr_Sort;
L #BITSET; //{0->(m-1)}[m]
>D ;
JC o1;
OPN DB [#DBNO_tempS];
A DBX [#ADDRESS_Sort];
JC o2;
L DBD [#DWNr_Sort];
OPN DB [#DBNO_tempH];
T DBD [#DWNr_Help];
L #DWNr_Help;
+ L#32;
T #DWNr_Help;
o2: NOP 0;
L #ADDRESS_Sort;
+ L#32;
T #ADDRESS_Sort;
L #DWNr_Sort;
+ L#32;
T #DWNr_Sort;
L #LOOPCOUNTER; //.
+ 1; //.
T #LOOPCOUNTER; //.
L #LOOPTIME; //.
MOD ; //.
L 0; //.
==I ; //.
JC FIN; //.
JU o3;
o1: L 0;
T #LOOPCOUNTER;
SET ;
= #SELECTIONBIT;
L #STEP;
+ L#1;
T #STEP;
BE ;
NETWORK
TITLE =
oo1: NOP 0;
o6: L #DWNr_Sort;
L L#0;
<D ;
JC o4;
AN DBX [#ADDRESS_Sort];
JC o5;
L DBD [#DWNr_Sort];
T DBD [#DWNr_Help];
L #DWNr_Help;
+ L#-32;
T #DWNr_Help;
o5: NOP 0;
L #ADDRESS_Sort;
+ L#-32;
T #ADDRESS_Sort;
L #DWNr_Sort;
+ L#-32;
T #DWNr_Sort;
L #LOOPCOUNTER; //.
+ 1; //.
T #LOOPCOUNTER; //.
L #LOOPTIME; //.
MOD ; //.
L 0; //.
==I ; //.
JC FIN; //.
JU o6;
o4: L 0;
T #LOOPCOUNTER;
CLR ;
= #SELECTIONBIT;
L #STEP;
+ L#1;
T #STEP;
L L#64;
<D ;
JC FIN;
CLR ;
= #BUSY;
FIN: BE ;
END_FUNCTION_BLOCK
DATA_BLOCK "FB1 DB"
TITLE =
VERSION : 0.0
"SORT FB"
BEGIN
START := FALSE;
DB_Sort := DB 1;
DB_Help := DB 1;
LOOPTIME := 0;
BUSY := FALSE;
START_FM := FALSE;
SELECTIONBIT := FALSE;
DBNO_Sort := W#16#0;
DBNO_Help := W#16#0;
BITSET := DW#16#0;
STEP := DW#16#0;
BIT_Sort := DW#16#0;
BIT_Help := DW#16#0;
LOOPCOUNTER := 0;
END_DATA_BLOCK
ORGANIZATION_BLOCK OB 1
TITLE = "Main Program Sweep (Cycle)"
VERSION : 0.1
VAR_TEMP
OB1_EV_CLASS : BYTE ; //Bits 0-3 = 1 (Coming event), Bits 4-7 = 1 (Event class 1)
OB1_SCAN_1 : BYTE ; //1 (Cold restart scan 1 of OB 1), 3 (Scan 2-n of OB 1)
OB1_PRIORITY : BYTE ; //Priority of OB Execution
OB1_OB_NUMBR : BYTE ; //1 (Organization block 1, OB1)
OB1_RESERVED_1 : BYTE ; //Reserved for system
OB1_RESERVED_2 : BYTE ; //Reserved for system
OB1_PREV_CYCLE : INT ; //Cycle time of previous OB1 scan (milliseconds)
OB1_MIN_CYCLE : INT ; //Minimum cycle time of OB1 (milliseconds)
OB1_MAX_CYCLE : INT ; //Maximum cycle time of OB1 (milliseconds)
OB1_DATE_TIME : DATE_AND_TIME ; //Date and time OB1 started
END_VAR
BEGIN
NETWORK
TITLE =
//TEST Netzwerk !
A [COLOR="Red"][B]I 0.7[/B][/COLOR];
FP M 100.0;
JCN w;
OPN "SORT DB";
L 1.047484e+001;
T DBD 0;
L -2.147223e+003;
T DBD 4;
L -1.474840e+001;
T DBD 8;
L 7.483600e+005;
T DBD 12;
L 1.474830e+002;
T DBD 16;
L 5.200000e+003;
T DBD 20;
L 1.470000e+000;
T DBD 24;
L -1.470000e+004;
T DBD 28;
L 1.470000e+003;
T DBD 32;
L 1.214510e+007;
T DBD 36;
L 6.612400e-001;
T DBD 40;
L 2.501000e+004;
T DBD 44;
L -1.590010e+003;
T DBD 48;
L 7.000000e+003;
T DBD 52;
L 1.123000e+000;
T DBD 56;
L 5.600100e+002;
T DBD 60;
L 1.000000e-004;
T DBD 64;
L 1.211101e+004;
T DBD 68;
w: NOP 0;
NETWORK
TITLE =
CALL "SORT FB" , "FB1 DB" (
START := [COLOR="red"][B]I 0.0[/B][/COLOR],
DB_Sort := "SORT DB",
DB_Help := "HELP DB",
LOOPTIME := 32767,
BUSY := [COLOR="Blue"][B]M 4.0[/B][/COLOR]);
END_ORGANIZATION_BLOCK
