A "CT" is a current transformer by anyone who has any electrical training. To call it anything else is a maliligned attempt to make yourself sound smarter than you really are.
Technically this is a correct statement therefore Allscott you have nothing to apologize for.
thanks, I appreciate that.
For me, "CT" can be used for a whole lot of things. I had a lot of time early in the instrumentation side of things and what jumped into my head came from years of acronyms from a small nitch in electronics.
The first fact to UNDERSTAND is at NO POINT did I state electronics.
If you saw CT used as an electrical term what would it mean to you?
I have been congenial on this up to now but you have attempted to discredit all comments just to be contrary and also rude to Allscott for stating what is a fact. I was not asking for opinion, I was asking for what is/was common to the electrical field.
I appreciate Brucechase comments about knowing more than some engineers but I know that is not the truth, even Bruce has chastised me in the past.
That said I have been in the "ELECTRICAL" field for over 20 years and KNOW I do not know everything BUT I have managed to retain some things over that period. Where I can help on sites like this is the fact that I have "time" and the ability to find information.
With all that said Terry stated;
At this point, the "CT" is NOT converting one form of energy to another. In this case, "current" begats "current". By definition, since the energy-forms are maintained, the "CT" is excluded from being classified as a "transducer".
I am not sure about this aspect because in some cases a "CT" had a voltage output, I think it was called a Rokowski coil...what it was used for I do not know because it has been too long, I just remember it and may not have spelled it correctly. I think that may qualify as one form of energy to another though.
Since a debate has been started PRS is the abbrevation most commonly applied to a proximity switch AND is designated by NFPA and others, again this is a device that is newer to the electrical field than other type switches so some may not follow the "standards".
WITH all the above said if at any point I or anyone else makes an improper statement then it should be corrected BUT in that process you do not have to rude or assinine.
